Merged Hide / Disable login
13 years 10 months ago #138946 by TKtemp
Joomla Administration -> Kunena Forum -> Kunena Plugins -> Edit "Kunena - Joomla Integration" plugin -> Enable Joomla Login = No -> Save
Hope this helps
13 years 10 months ago #138953 by sozzled
Replied by sozzled on topic Hide / Disable login
*** Topics merged ***
13 years 8 months ago #141845 by xpatman
Replied by xpatman on topic Turn off the log-in panel
Hi
I would like to remove or turn off the log in panel at the top of the forum.
There is a +/- icon but I would like to hide that panel permanently so they always use the main CB one on my site.
I have looked though the Forum Configuration but can not see anything about it.
Cheers
13 years 8 months ago #141849 by sozzled
13 years 8 months ago #142049 by dfgrbac
I have the latest versions of Joomla 2, JomSocial, Kunena, and EasyBlog. I want to use JomSocial for login/logout management, so I am trying to turn off the Kunena login form. This was easy to do in my main website which still uses old versions. Kunena used to have a configuration option for integrations, and there was an option to disable the Kunena login form.
I read during searches that the new way to do this is to edit the "Kunena - Joomla Integration" plugin and set "Enable Joomla Login" to "No". On my new site, this has no effect. The login form continues to show, although I noticed that selecting "Create an Account" does take it to JomSocial.
Can anyone help?
13 years 7 months ago #142051 by sozzled
