Important Forum Very Slow
17 years 7 months ago #13274 by PureMom
Forum Very Slow was created by PureMom
I wonder if someone could take a peek at our site and give me some hints as to why our brand new (IE: very few posts) is running extremely slow. When you click forums from the home page - it takes about 11 seconds to load. I have not added SEF in fear of slowing it down even more.
Would appreciate any tips! www.everythingmom.com/component/option,com_kunena/Itemid,4/
Thanks!
Michelle
Testing Signature...
17 years 7 months ago #13291 by Matias
Replied by Matias on topic Re:Forum Very Slow
It's not just the forum: the whole site is really slow.
In your front page index.php takes 5-7 secs to load at the first time and after that about 2-3 secs. Usually front page seems to be about two times faster than the forum.
Do you have one of those cheap hosting services? It looks like that there are way too many sites on that server.
17 years 7 months ago #13293 by PureMom
Replied by PureMom on topic Re:Forum Very Slow
We are on a managed virtual server, so that should not be it?
17 years 7 months ago #13294 by sudobashnet
Replied by sudobashnet on topic Re:Forum Very Slow
I suggest the Firefox addon YSlow. The following is a report card from YSlow as I ran it on the link you provided:
F 1. Make fewer HTTP requests
F 2. Use a CDN
F 3. Add an Expires header
F 4. Gzip components
A 5. Put CSS at the top
D 6. Put JS at the bottom
A 7. Avoid CSS expressions
n/a 8. Make JS and CSS external
A 9. Reduce DNS lookups
C 10. Minify JS
A 11. Avoid redirects
A 12. Remove duplicate scripts
F 13. Configure ETags
Otherwise Matias is probably correct in that your hosting servers are likely overcrowded and overworked.
17 years 7 months ago #13295 by PureMom
Thanks, will look into it!! :)
17 years 7 months ago #13296 by sudobashnet
lol, just ignore that report card. I ran the same test on my site (which loads very quickly) and its identical so more then likely Matias is right.
