Important Forum Very Slow
Would appreciate any tips! www.everythingmom.com/component/option,com_kunena/Itemid,4/
Thanks!
Michelle
Testing Signature...
In your front page index.php takes 5-7 secs to load at the first time and after that about 2-3 secs. Usually front page seems to be about two times faster than the forum.
Do you have one of those cheap hosting services? It looks like that there are way too many sites on that server.
- sudobashnet
- Junior Member
F 1. Make fewer HTTP requests
F 2. Use a CDN
F 3. Add an Expires header
F 4. Gzip components
A 5. Put CSS at the top
D 6. Put JS at the bottom
A 7. Avoid CSS expressions
n/a 8. Make JS and CSS external
A 9. Reduce DNS lookups
C 10. Minify JS
A 11. Avoid redirects
A 12. Remove duplicate scripts
F 13. Configure ETags
Otherwise Matias is probably correct in that your hosting servers are likely overcrowded and overworked.
- sudobashnet
- Junior Member
