- Thank you received: 1
Solved Male and Female Icons
16 years 6 months ago - 16 years 6 months ago #42375
by juuk
I am... Kunena 2.0.4 with CB 1.9 on Joomla 1.5.26.
Replied by juuk on topic Male and Female Icons
Here are my settings:
Parameters
Forum component: Kunena from www.kunena.com
Sidebar: Display Setting
Display setting: Basic (default kunena)
Forum Status: Display Settings
Display forum statistics: In User Profile
Parameters
Last edit: 16 years 6 months ago by juuk.
16 years 6 months ago - 16 years 6 months ago #42377
Replied by sozzled on topic Male and Female Icons
Very good!
Now I should like you to make two changes to those settings that I've highlighted in the following image:
- Change to Beginner (field selection).
- Select your custom-built gender field for the Kunena gender (see my earlier message #42315 for the title of your field)
Last edit: 16 years 6 months ago by sozzled.
16 years 6 months ago #42379
by juuk
Done as per instructed. Gender icon didn't appear still in side display
16 years 6 months ago #42383
OK, let's go back a step. Have you followed all the instructions given in my 20-cent guide to Community Builder? See
How to setup the cbsimpleboardtab plugin
. And, of course, you have defined, in the Kunena integration settings, to use your Community Builder profile with your forum, haven't you?
If you have done all of these things and this problem is not resolved they you should contact Joomlapolis (basically because it's their product). I expect that, one day, I will experiment with CB 1.2.2 but I don't have any urgent plans to do this just yet. If you discover that there is a defect with CB 1.2.2 with the integration to Kunena, that confirmed by Joomlapolis, would you please provide an update in this topic?
16 years 6 months ago #42384
by juuk
I shall inquire at Joomlapolis. Will update here when I get pointer(s).
Thank you so much for your help
16 years 6 months ago - 16 years 6 months ago #42391
juuk: After looking at your website, I notice that you have a lot of additional CB plugins (most of which I have no familiarity with), some of which may be unnecessary and some of which may be affecting your ability to run full native-mode Joomla 1.5. It's not that Joomla "legacy mode" is not supported, it's that J! 1.0 (and, by extension, anything developed for J! 1.0) is not supported and has not been supported for the past nine months. It is strategically wise, therefore, to remove any legacy components from your website, in any event, or to convert J! 1.0 software to J! 1.5.
As far as your specific issues are concerned, I see (from your installation) that CB 1.2.2 is slightly different to what I'm familiar with. I eagerly await any information you are able to obtain in relation to this new version and provide here for the benefit of Kunena uses.
Time to create page: 0.356 seconds
