Solved Male and Female Icons
16 years 6 months ago - 16 years 6 months ago #42606 by juuk
Replied by juuk on topic Male and Female Icons
sozzled wrote:
juuk: After looking at your website, I notice that you have a lot of additional CB plugins (most of which I have no familiarity with), some of which may be unnecessary and some of which may be affecting your ability to run full native-mode Joomla 1.5. It's not that Joomla "legacy mode" is not supported, it's that J! 1.0 (and, by extension, anything developed for J! 1.0) is not supported and has not been supported for the past nine months. It is strategically wise, therefore, to remove any legacy components from your website, in any event, or to convert J! 1.0 software to J! 1.5. B)
Noted with thanks! :)
I eagerly await any information you are able to obtain in relation to this new version and provide here for the benefit of Kunena uses. :)
The issue at hand is solved. See Joomlapolis solution.
NOTE: Before I did what the team Joomlapolis suggested, I reverted to CB 1.2.1, and the corresponding icons appeared. Now I'm back on CB 1.2.2!
Thanks, Sozzled for your invaluable assistance :)
I am... Kunena 2.0.4 with CB 1.9 on Joomla 1.5.26.
Last edit: 16 years 6 months ago by juuk.
The following user(s) said Thank You: Baze
16 years 6 months ago #42630 by sozzled
Replied by sozzled on topic Male and Female Icons
Congratulations on your success. That's a fairly bizarre twist in the tale but I'm happy to hear that Joomlapolis have discovered a solution even though it doesn't appear to be one "out-of-the-box".
The following user(s) said Thank You: migus
16 years 4 months ago #47701 by tisiman
Replied by tisiman on topic Male and Female Icons
I had the same problem, all settings seemed as discussed/proposed previously. Then, as experienced by juuk, I uninstalled component comprofiler, installed version 1.2.1 (with some errors about arrays expected differently), uninstalled component comprofiler again, and installed com_comprofiler.zip of 1.2.2 again. Everything looks as before (did not have to restore administrator\components\com_comprofiler\ue_config.php). I only had to enter the gender data of all users again. Now the gender icon appears properly. I did not try skipping some steps, it works now and I am happy.
16 years 2 months ago #51795 by migus
Replied by migus on topic Male and Female Icons
Thanks a lot for this thread. It appears very useful to me.:woohoo:
Altai Mountains - is a fairy tale!
15 years 9 months ago #75601 by Baze
Replied by Baze on topic Male and Female Icons
Thanks for this one, i've been struggling with it for a while :)
Time to create page: 0.302 seconds
