Solved Male and Female Icons
16 years 6 months ago #42309 by juuk
Replied by juuk on topic Male and Female Icons
sozzled wrote:
First of all, I haven't yet installed CB 1.2.2 and so I don't know what changes have been made, but this guide is based on my knowledge of CB 1.2.1 and so you may have to adapt it as necessary:
  1. Using the CB Field Manager, create a new field named Gender (CB will store this as cb_gender)
  2. Create the field as type "Drop Down (Single Select)". You will need to assign two named values: one will be Male, the other will be Female
  3. Assign this new field to a CB profile tab
  4. Modify a CB user profile (go to the tab that you assigned earlier) and click the appropriate radio button to select and assign a gender to the user)
CB and Kunena have enough "smarts" to use your custom-defined Gender field and the two values you've assigned in the cbsimpleboardtab plugin (as long as you've published that plugin).
Thus far, I've done steps 1 & 2.
Step 3 is not in a profile tab but in profile item. Will that make a difference?
Also done step 4.
Gender icon still didn't appear :(.
You think it has to do with CB 1.2.2? :unsure:
I am... Kunena 2.0.4 with CB 1.9 on Joomla 1.5.26.
16 years 6 months ago #42315 by sozzled
Replied by sozzled on topic Male and Female Icons
Please see the following image:
This is something that you should take up with the folks at Joomlapolis .
16 years 6 months ago #42331 by juuk
Hi Sozzled. Thanks for the clarification. Field is assigned to a CB profile tab.
16 years 6 months ago #42332 by sozzled
So everything works now? :dry:
16 years 6 months ago #42337 by juuk
Whoops! I forgot to mention... No gender icon still. I need to step out. Perhaps when I'm back in about 3-4 hours, if you're around, I can give you my site's backend access, and you can take a look-see?
16 years 6 months ago - 16 years 6 months ago #42368 by sozzled
I know that this problem can be solved because I have solved it. Unfortunately I only now have the settings on my website to show me how I achieved my success ... which haven't been able to help you. :blush:
There is one other possibility that you may need to consider. Go to Components » Community Builder » Plugin Management. Locate and edit the Forum integration item (cbsimpleboardtab). See the following image:
(Again, the information and instructions contained herein are based on my knowledge of CB 1.2.1)
Please ensure that you have selected Kunena as the forum component. The item (highlighted in yellow) is located at the top right of the image. This is important ... it is also not the default! ;)
By default, the sidebar mode - this is how you associate CB fields with Kunena - is normally shown (as I've highlighted it in yellow) as "Basic (default kunena)".
Please confirm if your settings are as I've shown above. Although this may not resolve your situation, I want to know what you currently have.
Last edit: 16 years 6 months ago by sozzled.
Time to create page: 0.280 seconds
