Question [Resolved] Guest Avatar Not Showing Up After Upgrade
16 years 2 months ago #40932 by sozzled
After a lot more poking around, there is a difference if you select
Integration » Avatar Integration » Use avatar picture from = Community Builder
as opposed to
Integration » Avatar Integration » Use avatar picture from = Kunena
In the former case, guest posters have no avatars. In the latter case, guest posters have an avatar. This looks more likely to be a Kunena issue. Surprisingly, over six months after Kunena and Community Builder "came together", this has only now been detected!
The topic has been locked.
16 years 2 months ago #40934 by brentwilliams3
Just to make sure we are seeing the same thing...
When I changed it to "Kunena", yes, there is now an avatar for the guests. However, all the avatars are the same (I'm guessing the standard avatar for those who don't have a photo).
Is this what you were seeing?
16 years 2 months ago - 16 years 2 months ago #40935 by sozzled
Of course! If you were using CB avatars, before you switched to a different source of avatar images, then very few (if any) people would have avatars, would they? ;)
The situation is different on your development site (where I posted a test reply). But I have no understanding of why.
Are you using different versions of Kunena on these two websites?
16 years 2 months ago #40945 by brentwilliams3
doh! :blink:
YES! The dev server is using Kunena 1.5.6 - I forgot that I went ahead and used the latest version when I finally got it upgraded on my live site...
16 years 2 months ago #40946 by sozzled
So, is the problem something that may have occurred between K 1.5.6 and K 1.5.9, perhaps? How can we ascertain this? :S
And, perhaps from the developer's perspective, why? :side:
16 years 2 months ago #40948 by brentwilliams3
Hmmm... Not sure. Right now it's seeming to be either that or the GJ Extended Plugin, as those are the only differences I can think of right now. I should hopefully have the plugin installed in a couple of days, so maybe we can cross that off the list.
By the way, if there is ever an award for best moderator for a website, I am definitely nominating you!
