Question [Resolved] Guest Avatar Not Showing Up After Upgrade
16 years 7 months ago - 16 years 5 months ago #40594 by brentwilliams3
I recently upgraded from 1.0 to 1.5.9, and everything seems to be working except the avatar for guest posting isn't showing up properly. The image link seems to be my domain name and that's all.
Any ideas?
Thanks!
Last edit: 16 years 5 months ago by sozzled.
The topic has been locked.
16 years 7 months ago #40595 by sozzled
What does the image URL structure look like?
16 years 7 months ago #40602 by brentwilliams3
Thanks for the reply! But I'm not exactly sure what you are asking for. Do you mean the image structure for the site overall or for Kunena specifically?
Thanks!
16 years 7 months ago #40606 by xillibit
just check that the guest image avatar is correct, you need to have something like that : /joomla/media/kunena/attachments/legacy/avatars/s_nophoto.jpg
16 years 7 months ago #40753 by brentwilliams3
Thanks for the response, and I do have that file in the proper place. But I don't think the image itself is the problem. On the page where the image is supposed to appear, when I look at the image properties, it says the path is: " www.multifamilyinsiders.com/home/ ", which is my main subdirectory that Joomla is installed on. In other words, it's not pointing to a picture at all.
So I need to find where it is defining where to look for the guest avatar in the code... Any ideas on where that might be?
Thanks!
16 years 7 months ago #40762 by xillibit
Look in components\com_kunena\template\default_ex\view.php at lines 597 to 606.
Time to create page: 0.259 seconds
