Question Kunena and JomSocial. And the signature?
15 years 3 months ago #99350 by sababer9
have you followed these steps:
You have to follow these steps:
1. This code is to be added in a new file "forumsignature.php" created in /components/com_community/libraries/fields.
2. Edit the file "customfields.xml" and add new field tag:
<field>
<type>forumsignature</type>
<name>Forum Signature</name>
</field>
3. Now go into backend menu Components -> Jomsocial -> Custom Profiles -> New Field
4. Select "Forum Signature" and you are done.
Regards
tuumke wrote: JomSocial Version: 2.2.2
Joomla! Version Joomla! 1.6.3 Stable
Installed version: Kunena 1.6.4
We do have an extra field in the profile, but the signature does not appear in Kunena
i've tried with <?php at beginnen, ?> at the end...
all dont work
-edit-
It's puttin the info in: jos_community_fields_values
even when you change
$query = "SELECT signature FROM #__kunena_users WHERE userid = $userid";
to
$query = "SELECT signature FROM jos_kunena_users WHERE userid = $userid";
15 years 3 months ago #99352 by tuumke
yes! :)
Hence, the <?php story ;-)
I've added the My Kunena Menu or something, so people can edit there forum signature for now, but i'd like it to be in the normal profile menu.
15 years 3 months ago #99353 by sababer9
make sure you have "signature" named field in kunena users table
15 years 3 months ago - 15 years 3 months ago #99356 by tuumke
How do you mean?
i've tried with
to
but it still takes it from jos_community_fields_values and also puts it in there.
With the my kunena toolbar for jomsocial, you can edit your forum profile, which does show the
signature. So i think it might be in the query somehow.
Last edit: 15 years 3 months ago by tuumke.
15 years 3 months ago #99358 by sababer9
can you send me a checkbox.php file from fields folder? so that i can see what technique jomsocial 2.0 is using?
15 years 3 months ago - 15 years 3 months ago #99365 by tuumke
This is the code from the file
<?php /** * @copyright (C) 2008 by Slashes & Dots Sdn Bhd - All rights reserved! * @license GNU/GPL, see LICENSE.php */ // no direct access defined('_JEXEC') or die('Restricted access'); class CFieldsCheckbox { public function _translateValue( &$string ) { $string = JText::_( $string ); } /** * Method to format the specified value for text type **/ public function getFieldData( $field ) { $value = $field['value']; // Since multiple select has values separated by commas, we need to replace it with <br />. $fieldArray = explode ( ',' , $value ); array_walk($fieldArray, array('CFieldsCheckbox', '_translateValue')); $fieldValue = implode('<br />', $fieldArray); return $fieldValue; } public function getFieldHTML( $field , $required ) { $class = ($field->required == 1) ? ' required validate-custom-checkbox' : ''; $lists = is_array( $field->value ) ? $field->value : explode(',', $field->value); $html = ''; $elementSelected = 0; $elementCnt = 0; $cnt = 0; CFactory::load( 'helpers' , 'string' ); $class = !empty( $field->tips ) ? 'jomTips tipRight' : ''; $html .= '<div class="' . $class . '" style="display: inline-block;" title="' . JText::_( $field->name ) . '::' . CStringHelper::escape( JText::_( $field->tips ) ). '">'; if( is_array( $field->options ) ) { foreach( $field->options as $option ) { $selected = in_array( JString::trim( $option ) , $lists ) ? ' checked="checked"' : ''; if( empty( $selected ) ) { $elementSelected++; } $html .= '<label class="lblradio-block">'; $html .= '<input type="checkbox" name="field' . $field->id . '[]" value="' . $option . '"' . $selected . ' class="checkbox '.$class.'" style="margin: 0 5px 5px 0;" />'; $html .= JText::_( $option ) . '</label>'; $elementCnt++; } } $html .= '<span id="errfield'.$field->id.'msg" style="display: none;">&nbsp;</span>'; $html .= '</div>'; return $html; } public function isValid( $value , $required ) { if( $required && empty($value)) { return false; } return true; } public function formatdata( $value ) { $finalvalue = ''; if(!empty($value)) { foreach($value as $listValue){ $finalvalue .= $listValue . ','; } } return $finalvalue; } }
Time to create page: 0.268 seconds
