Question Kunena and JomSocial. And the signature?
Which file do edit for the language for for forum settings and so on, been browsing but luck, thanks again
This is using the Joomla language files. You can find the one for the plugin inside the plugin folder and it is called:
en-GB.plg_mykunenatoolbar.ini
copy this and replace en-GB with your language code, change the content and it should work based on your Joomla install language settings.
If people can provide this file in various languages, I can include that in new builds.
The Kunena screens that will pup up once you click any of those menu items, is standard Kunena and needs to be modified as part of the Kunena language files.
Hope this helps!
Thank you
That should fix it for all of you running on older than 1.6 jomSocial.
Let me know if there are any more issues.
