- Thank you received: 1
Question Kunena and JomSocial. And the signature?
You have to follow these steps:
1. This code is to be added in a new file "forumsignature.php" created in /components/com_community/libraries/fields.
2. Edit the file "customfields.xml" and add new field tag:
<field>
<type>forumsignature</type>
<name>Forum Signature</name>
</field>
3. Now go into backend menu Components -> Jomsocial -> Custom Profiles -> New Field
4. Select "Forum Signature" and you are done.
Regards
mibnbikes wrote: Hi there,
could you please provide us with screenshot or a live test site/example?
Which file should I modify?
Best regards Mikkel.
"Do or do not, there is no try..."
sababer9 wrote: Hey guys,,
Studies few earlier messages in this post for the same requirement, the signautre integration with jomsocial. I think you ppl have got the solution with a plugin may be.
in the meantime, i built up my own solution, thought it might help anyone there.
Its an extra field in jomsocial which picks and puts signature in kunena table with following code.
// no direct access
defined('_JEXEC') or die('Restricted access');
class CFieldsForumSignature
function getFieldHTML( $field , $required )
$config =& CFactory::getConfig();
$js = '/assets/validate-1.5';
$js .= ( $config->getBool('usepackedjavascript') ) ? '.pack.js' : '.js';
CAssets::attach($js, 'js');
// If maximum is not set, we define it to a default
$field->max = empty( $field->max ) ? 200 : $field->max;
$loggedInUser =& JFactory::getUser();
$userid = JRequest::getVar('userid',$loggedInUser->id,'get');
$db =& JFactory::getDBO();
$query = "SELECT signature FROM #__kunena_users WHERE userid = $userid";
$db->setQuery($query);
$field->value = $db->loadResult();
$class = ($field->required == 1) ? ' required' : '';
CFactory::load( 'helpers' , 'string' );
$html = '<textarea id="field' . $field->id . '" name="field' . $field->id . '" class="jomTips tipRight inputbox textarea' . $class . '" title="' . $field->name . '::' . CStringHelper::escape( $field->tips ) . '">' . $field->value . '</textarea>';
$html .= '<span id="errfield'.$field->id.'msg" style="display:none;"> </span>';
$html .= '<script type="text/javascript">cvalidate.setMaxLength("#field' . $field->id . '", "' . $field->max . '");</script>';
return $html;
function isValid( $value , $required )
if( $required && empty($value))
return false;
$userid = JRequest::getVar('id',$loggedInUser->id);
$query = "UPDATE #__kunena_users SET signature ='$value' WHERE userid = $userid";
$db->query();
return true;
Regards,
The signature from jomsocial
Just 1 thing. This works perfectly but you forgot something.
Do not forget to put the following in front off the code above.
Then it all works fine!
Installed version: Kunena 1.5.14
js 2.2.0
Joomla! Version Joomla! 1.6.3 Stable
Installed version: Kunena 1.6.4
We do have an extra field in the profile, but the signature does not appear in Kunena
i've tried with <?php at beginnen, ?> at the end...
all dont work
-edit-
It's puttin the info in: jos_community_fields_values
even when you change
to
$query = "SELECT signature FROM jos_kunena_users WHERE userid = $userid";
