Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 1 month ago #29246 by bulesz
How can I make the avatars links to the profile? or the message?
Many thanks,
B.
17 years 1 month ago #29272 by xpozay
You need to use the %A attribute to display the avatar. If you mouse over the item format, it will give you a list of all the parameters.
17 years 1 month ago - 17 years 1 month ago #29273 by xpozay
Solved (not me) the the jquery conflict between kunena and Jomsocial when you have both this module (kunena latest) and the jomsocial hello_me module enabled on the frontpage.
The fix can be found here.
www.jomsocial.com/webforum/viewtopic.php...7644&start=30#p55717
After applying this patch, you can edit the jomsocial status and use this module properly.
Last edit: 17 years 1 month ago by xpozay.
17 years 1 month ago #29304 by bulesz
yes, thanks, i know that (I have made my div based template for that...)
I need to know just is that possible to make the avatar linked to the profile?
(as default just show the avatar, but cant click on it...)
Many thanks,
B
17 years 1 month ago #29379 by Soulmaster
Replied by Soulmaster on topic Module error
i got a strange error in my latetst module
Notice: Use of undefined constant KUNENA_ABSPATH - assumed 'KUNENA_ABSPATH' in /home/hlnhe/domains/hlnhe.nl/public_html/modules/mod_kunenalatest/helper.php on line 23 Warning: include_once(KUNENA_ABSPATH/template/default/icons.php) [function.include-once]: failed to open stream: No such file or directory in /home/hlnhe/domains/hlnhe.nl/public_html/modules/mod_kunenalatest/helper.php on line 23 Warning: include_once() [function.include]: Failed opening 'KUNENA_ABSPATH/template/default/icons.php' for inclusion (include_path='.:/usr/local/lib/php') in /home/hlnhe/domains/hlnhe.nl/public_html/modules/mod_kunenalatest/helper.php on line 23
is what i'm seeing before i see the discussions.
17 years 1 month ago - 17 years 1 month ago #29450 by TPH
Replied by TPH on topic Re:Kunena latest posts module
SOLVED: I used the TABLE format instead of LIST.
So why won't it show the avatars? Other than that...yeah! love how we can filter users by specific CB fields. That will help!
Okay -- fixed the avatars. But the alignment is off....Here's a screen shot
Last edit: 17 years 1 month ago by TPH.
