Kunena 7.0.8 Released
Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
17 years 1 week ago #27760
by pjotr
Replied by pjotr on topic problem with Kunena latest module 1.0.45
After installing module KunenaLatest v 1.0.45 My site will not appears annymore. The following error appears:
Fatal error: Class 'fb_config' not found in /home/vpo/domains/xxxxx.nl/public_html/modules/mod_kunenalatest/helper.php on line 7
When I disable the module the site is working again. What is the cause of this error?
- wingnut144
- Senior Member
17 years 3 days ago #28226
by wingnut144
Replied by wingnut144 on topic Re:Kunena latest posts module
I just installed this module and have a question. Users avatars are not showing up, even though I have enabled them in the module.
The board in question is at www.salleboise.com if that helps.
What could be causing this?
17 years 1 day ago #28381
by xpozay
Replied by xpozay on topic Re:Kunena latest posts module
Hi Jerry,
Long time since we have crossed paths - since the FB days of your first release. I have been getting an JQuery conflict on my homepage when I enable the latest posts module - with the Jomsocial Hello_me module. The exact message is:
jQuery is not defined
mydomain.com/components/com_community/assets/script-1.2.js
This also stop my "edit my status" on the hello_me from working correctly - I assume because the above script is not loaded.
If I disable the latest_posts module the error goes away. I have read a number of threads here, in kunena, and in the jomsocial forum without getting a working fix. The closest I get is here with this thread
www.kunena.com/forum/139-solved-or-prior...with-jomsocial#21127
which does not work for me.
Any advise on how I might go about fixing this.
I am using:
- Joomla 1.5.14
- JS 1.2.206 (and its hello_me)
- Kunena 1.5.4
- Kunenalatest 1.0.41 (also tried 1.0.45)
Thanks in advance
Note: I am posting a similar request for help in the jomsocial forum.
I am using:
- Joomla 1.5.14
- Kunena 1.5.4
Thanks in advance
16 years 11 months ago #28770
by kaumac
Replied by kaumac on topic Re:Kunena latest posts module
hey there! just a quick question, how do I have to do to make %N to show the person“s name instead of the username? Thx a lot!
- wingnut144
- Senior Member
16 years 11 months ago #28818
by wingnut144
If I have Kunena getting the user avatars from JomSocial, then why is this module not then displaying those same avatars on the page for the latest posts?
Is there something else I need to do to get this to work??
- wingnut144
- Senior Member
16 years 11 months ago #29039
by wingnut144
Anyone???? Any ideas are appreciated.....
Time to create page: 0.300 seconds
