Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
16 years 10 months ago #24205 by jerry
Replied by jerry on topic Re:Kunena latest posts module
kankaanp wrote:
If you try to leave tooltip field on the backend empty it bounces back to default (%F > %L). This probably not bug but a useful safety. BUT if you try to set it to anything else, it ceases to be a tooltip but throws the stuff in the module just before whatever you have for a line (mine is %R %S). A bug or a need to do a clean install of the module?
Tried, it works for me. (%R %S as tooltip).
Version 1.0.44.
16 years 10 months ago #24452 by jerry
version 1.0.45 - fixed %N %D in tooltip format
16 years 10 months ago #24453 by jerry
kankaanp wrote:
I've tried to set the values of Item format and Tooltip format so that the Item is just the short subject with the unread indicator before it (%R %S) and the tooltip format so that it has rest of the information: forum, the whole subject, name of the poster and date, as I understand the admin side tooltips right this should be accomplished by setting the tooltip format to %F > %L %D %N for instance. If I fo this I get screwed display of the module with the date and name before the short subject with "> separating them. (This surely is not what it is meant to do!) If I set the tooltip to %F > %L it works fine but a few other combinations I've tried don't work either. The odd thing is, the erraneous results seems to be same everytime. (Of this I'm not completely sure...) So are you telling me, that the tooltip cannot actually be used to hold all the parameters that are listed in the admin side tooltip - and if so, why the hell are they there?!
Should be resolved in version 1.0.45.
16 years 10 months ago #24480 by Grubbe
Hi.
I have installed the Latest post module and it works fine!
However, I can only assign it to the menu.
On my frontpage I have to columns: My site . Is it possible to assign the latest posts module to the left column? Maybe I could put a script in the article that will load the module and then show it in the article?
Best regards, Lasse.
16 years 10 months ago #24502 by Lintzy
16 years 10 months ago #24511 by Grubbe
Thanks. Fast answear as usual :)
That should do it...
