Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
16 years 11 months ago #24513 by stringo0
I seem to be having trouble with 1.0.45 - none of the options seem to be saving. For example, display type (always using list), item format (even if I remove everything and only put in %S)
Any ideas why?
16 years 11 months ago #24519 by jerry
Replied by jerry on topic Re:Kunena latest posts module
Any ideas why?
Actually settings are saved by Joomla itself, there's only 1 xml file in my module which names all the parameters. That's all from module side. So try, if there isn't problem with other modules. You could try core Joomla modules. Looks like problem with Joomla itself.
16 years 11 months ago #24560 by stringo0
The other Kunena latest posts module seems to work fine. The settings are saved etc. - for this module the settings are saved in the module itself (when I save/apply etc. the settings are still there in the backend), but they are not actually reflected in the module - the module looks default even after changing settings.
I wouldn't mind giving you an admin login to the site if you'd like to check it out for yourself.
16 years 11 months ago #24562 by jerry
PM me url & user/pass.
16 years 11 months ago - 16 years 11 months ago #24574 by jerry
Checked. Enabled cache 'holds' settings until cache expires. That's expected behavior. Disabling cache make changes visible immediately.
Last edit: 16 years 11 months ago by jerry.
16 years 11 months ago #24584 by stringo0
Thanks for the excellent support!
Time to create page: 0.240 seconds
