- Thank you received: 1
This category is for the plugin developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 1.6 and later versions.
Question Kunena Discuss create hundreds of posts on my forum :/
14 years 8 months ago #103958
by polki
Replied by polki on topic Re: Kunena Discuss create hundreds of posts on my forum :/
oh, even if i delete all the posts, they are still in the database ?
ok thanks, will wait
but how can i be sure that this bug will be fixed for the 1.6.5 ?
14 years 8 months ago #105449
by badabugs
Replied by badabugs on topic Re: Kunena Discuss create hundreds of posts on my forum :/
I found something today :
www.kunena.org/forum/11-jomsocial/102606...cial-activity-stream
Disable activity stream in kunena integration tab : it works !
The following user(s) said Thank You: polki
14 years 8 months ago #105472
by Matias
Replied by Matias on topic Re: Kunena Discuss create hundreds of posts on my forum :/
Ok, so there's an issue with JomSocial activity stream integration, but only in some sites (here it works just fine). Please check that you haven't enabled any activity stream plugin that causes the issue.
14 years 8 months ago #105508
by badabugs
no more than i had on joomla 1.6.5 (I've only official plugins) ... I could be an issue with joomla 1.7 ...
14 years 8 months ago #105510
by Matias
That can be true. So the issue started after..? What did you do?
14 years 8 months ago #105585
by badabugs
I don't remember if KD was installed when i had 1.6.5 on my website...
(i used another component for comments)
This issue is always here with kunena 1.7 :S
IF you want an account on my website to check this issue, you're welcome ...
