This category is for the plugin developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 1.6 and later versions.
Question Kunena Discuss create hundreds of posts on my forum :/
15 years 1 month ago - 15 years 1 month ago #103755 by polki
Hi, and thanks for this great plugin !
i'm having a big issue :/
Using J1.7 + Kunena 1.6.5 + Kunena Discuss 1.6.4
In my frontpage i have the qAccordion module that display full articles in accordions.
When i clic on Read More ( i've checked "create post on visit" ) it load for 5-6sc then shows me a Internal error 500.
And then, when i go to my forum, there are like 150 post copies
and when, with a miracle it works, when i clic on Read More ( that create the post on the forum ) a message display an error saying : -post: Duplicate. Identical message has been ignored
someone is having the same problem ?
Thanks in advance :)
Last edit: 15 years 1 month ago by polki.
15 years 1 month ago - 15 years 1 month ago #103756 by polki
edit : not solved, still has this problem
15 years 1 month ago #103762 by xillibit
Please update kunena to 1.6.5 version and plugin discuss to 1.6.4
15 years 1 month ago #103796 by polki
hi
my bad,
when i said : Using J1.7 + K1.6.4
K1.6.4 is the K Discuss plugin version :p
so
I'm using K1.6.5 and Kunena Discuss 1.6.4 :)
15 years 1 month ago #103913 by polki
no one can help me ? :/
15 years 1 month ago #103955 by badabugs
I had the same problem ... disable kunena discuss and clean up your database ! (i had more than 1200 posts created in few minutes) !)
Waiting for KD 1.6.5 is the best answer you can read here ... ;)
