- Thank you received: 565
Question Kunena Discuss create hundreds of posts on my forum :/
If so, we have another issue in the plugin.. I may have an idea: do you have upper case letters in your Joomla table prefix setting (configuration.php)?
Matias wrote: Did you also upgrade Kunena Discuss?
Yes, I upgrade everything.
No, I don't have upper case letters in my joomla table prefix setting (configuration.php)
I don't think that there are other ways than to see what's happening in your environment.
Are there others who are still having the same issue?
MaybeMatias wrote: So your issue is that Kunena still creates a lot of topics on a single page load? It shouldn't be possible as we prevent plugin from being loaded more than once; maybe there's something else that's going on...
I'm curious tooAre there others who are still having the same issue?
yes, i have the same problem...
when i try to write a message i get this error:
Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 523800 bytes) in kunena.parser.php on line 271
J¡1.7.2 K and Kd 1.7.1 jomsocial 2.4
So, no, it is clear that you do not have "the same problem" as audioindo has and you should look to fix your out-of-memory error message in another way.
