Question Kunena Discuss create hundreds of posts on my forum :/
- Acapulco Kevin
- Junior Member
I have VPS and compiled Apache and PHP 5.2.17
The first time I used the comment box for kdiscuss it created over 300 messages in under a second.
I simply deleted the category from the back end and created a new one, changed the number in kdiscuss and it stopped happening.
Now when I post the first comment on a new article I get this:
* -post-: Duplicate. Identical message has been ignored.
* -load-: An invalid post ID was requested.
Message
* Your message has been posted.
I have thus changed the following:
SEO Settings
Search Engine Friendly URLs : NO
Do Not Use Category IDs: YES
Enable UTF-8 Support: YES
Does not make a difference either way, I get the same message. I have had a horrible time trying to get the latest plugins to work correctly with the latest joomla and latest kunena forum package.
In the past Kunena has been wonderful, works great.. Now it just seems very buggy and incompatible with Joomla 1.7
I have same problems here, is there any solution yet?
And how to delete this thousands post in once? What database table should I go, and what the syntax?
Thank you
Is the kunenadiscuss 1.7.1 the answer of our problem?
