- Thank you received: 1
This category is for the plugin developed, endorsed, maintained and supported by the Kunena project team. The topics in this category only relate to the plugin developed for K 1.6 and later versions.
Question Kunena Discuss create hundreds of posts on my forum :/
15 years 1 month ago #105655
by polki
Replied by polki on topic Re: Kunena Discuss create hundreds of posts on my forum :/
thanks it works
15 years 1 month ago #105723
by Matias
Replied by Matias on topic Re: Kunena Discuss create hundreds of posts on my forum :/
At this point I'd rather have the error message if there's one and as much of information how/when to reproduce it.
15 years 1 week ago #108063
by pappabear
Replied by pappabear on topic Re: Kunena Discuss create hundreds of posts on my forum :/
I'm now having this issue all of a sudden. I do not know the cause.
I have over 20,000 topics being created whenever I enable kunena discuss, then my server crashes.
I tried installing Kunena 1.7 along with KD 1.7, (I was using a hacked version of 1.6.4 kd before) and it has not fixed the problem.
- martijn189
15 years 3 days ago - 15 years 3 days ago #108286
by martijn189
Replied by martijn189 on topic Re: Kunena Discuss create hundreds of posts on my forum :/
i also have this issue, i do have jomsocial installed. Is there a workaround for this? i rether have jomsocial activity stream enabled.
Last edit: 15 years 3 days ago by martijn189.
15 years 1 day ago #108362
by yuzef
Love Simplicty
read...... and learn........
My Joomla Test Site
Replied by yuzef on topic Re: Kunena Discuss create hundreds of posts on my forum :/
Is there any solution for this issue ?
i still got that problem..
On Joomla 1.7.1 - Kunena 1.7 anda Jomsocial 2.2.4 : All of this is with default configuration and fresh Installation.
When i enable the discuss plugin its will create thousand of new topic. the server crashed
Love Simplicty
My Joomla Test Site
14 years 11 months ago #108578
by Matias
There's not much that I can do as I have no idea what is happening and where / when it happens. I cannot reproduce the issue with or without JomSocial.
It does look like that this issue only happens if JomSocial is installed, but what triggers this -- I have no glue. I also don't know if it can happen in frontend or if it happens only if you add article in Joomla backend.
The issue looks like the server is redirecting back to the same page, again and again, but for some reason discuss plugin fails to detect the existing topic (it's perhaps missing from the table).
Information what I'm missing is:
1) In which page does this happen (where did you go)?
2) Does it happen in frontend or backend?
3) Do you have JomSocial installed or not?
4) Are you in J1.7 or J1.5?
The same data from everyone should at least point me into the right direction.
Time to create page: 0.265 seconds
