Question [RESOLVED] Font size in message editor is too small; users cannot read it
15 years 9 months ago #84791 by sozzled
It's really quite simple. severdia's reply earlier contains the relevant information.
If you're only interested in changing the font size, add the following three lines to the end of your Joomla site template CSS file:
#Kunena .kreply-form .inputbox {
font-size:12px !important;
If you don't like 12px, try some other value (e.g. 14px or 16px) until you see a change that you can live with.
15 years 5 months ago #96930 by cdawolf
The answer is not in the inputbox
It's in this part:
#Kunena table#kpostmessage .ktxtarea {
border: 1px solid #BFC3C6;
height: 200px;
overflow: auto;
I added in there the font size...now it looks like this:
font-size: 14px;
height: 200px;
overflow: auto;
It works like a charm now!
The following user(s) said Thank You: KimH
15 years 5 months ago #96938 by KimH
cdawolf wrote: The answer is not in the inputbox
It's in this part:
height: 200px;
overflow: auto;
font-size: 14px;
height: 200px;
overflow: auto;
Thanks man, this fixed my problem :-)
15 years 5 months ago #97022 by dimonju
Can someone help me out in this?
I'm facing the same problem in K1.6.4 and I'm using the default blue eagle template.
In which css file should I insert that code you are mentioning?
Is it Joomla's or Kunena's?
If it is Kunena, the template has 8 css files.
Also, some are marked as unwritable.
I appreciate some help,
15 years 5 months ago - 15 years 5 months ago #97026 by sozzled
You add the code to the end of your Joomla site template file. If you add the lines of CSS to your Joomla site template file you will not ever have to worry about changing this again when you upgrade Kunena. Simple.
Last edit: 15 years 5 months ago by sozzled.
15 years 5 months ago #97057 by cdawolf
@dimonju
You either put it in your template.css or you change it directly to your kunena template file.
In the later case,the file needed is components/com_kunena/template/default/css/kunena.forum-min.css
Yet in the case of changing it in that template,bare in mind that if you change the template,
you need to implement that change in the new template's kunena.forum-min.css file as well!
