Question [RESOLVED] Font size in message editor is too small; users cannot read it
16 years 1 month ago - 15 years 5 months ago #64865 by jodin
Hey
I cannot change the font size in the reply editor input box.
I changed this: in kunena.forum.css
#Kunena .kreply-form .inputbox {
background:none repeat scroll 0 0 #FFFFFF;
border:1px solid #999999;
color:#000000;
font-size:12px; <---- I added this line
margin:2px 0;
I remized it to kunena.forum-min.css and uploaded to the example/css dir
I am using the example template(I checked the view source)
The file is being updated when I ftp to my server. I checked that too.
The font-size:12px; statement is there when I view css from Kunena template manager.
I was able to fix this in rc2 and rc3. It's not updating in final release.
I checked the code in Firebug and the font-size:12px; statement is there.
The subject text input is fine with size. My users cannot read the text in the input box. It's too small. I don't know why you did not make the input box font a readable size in the final release of 1.6. This is the smallest text I've ever seen in any forum software.
Please help!!!!
Last edit: 15 years 5 months ago by sozzled. Reason: Change topic status
16 years 1 month ago #64962 by sozzled
I think I know what's happening here. You've made a change to the Kunena template CSS file ../components/com_kunena/template/default/kunena.forum.css but your don't see the effects of those file changes. This is because, by default, K 1.6 does not actually use that file; it uses a minified version of that file. See Minified CSS for a detailed explanation about how file minification works and how to create a minified CSS file for your Kunena installation.
Even so, even if you have applied your changes to the minified CSS file, you may not notice any difference. This is because your browse cache is still using the older version of the CSS file. You may also need to force your browser to refresh and replace the CSS file in your local cache.
I hope this helps.
16 years 1 month ago #64992 by severdia
Did you try?
#Kunena .kreply-form .inputbox { background:none repeat scroll 0 0 #FFFFFF; border:1px solid #999999; color:#000000; font-size:12px !important; margin:2px 0; }
16 years 1 month ago #66218 by KimH
After upgrading to Kunena 1.6 I have noticed that the text size in the message compose area is very small (see screenshot)
How can I change this to normal size?
/Kim
15 years 9 months ago #84783 by KimH
@Jodin: Did you ever find a solution to this issue? I have noticed that the problem is worth when using Google Chrome compared to using Internet explorer...
Anyone?
Regards
Kim
