Question [RESOLVED] Font size in message editor is too small; users cannot read it
i try both solutions , compress the forum.css file in minified css but no more
an idea ?
thanks
Please read the FAQs page (under the section that reads " How do I change the colours of my template in Kunena? ").
jsgros wrote:
Yes, I have lots of ideas. How about trying to use Firebug (or some other web design tool) to diagnose and fix the CSS? Try modifying your site template CSS file instead of trying to play with the Kunena template CSS file(s), as suggested in the FAQs page? This is not a Kunena problem, is it? I mean, you don't have a problem with the font size at this website ( www.kunena.org ), do you?an[y] idea?
- toonoflancing
I'm trying to find out why the text is so small in the editor but seem to go round in circles. There's all sorts of comments arounf about what should be changed but none of it worked for me.
Before anyone jumps down my throat about my confoiguration being the problem here's a screen shot from YOUR forum where I'm typing this message:
Is there no parameter setting in your package for choosing what text size the visitor sees and uses?
Regards
Howard
You can't set the size of text like that, you have maybe a specific joomla! template which set a small size of text. Try to look with firebug, if you can change something
I think it's fair to say that this is a question that we are asked often. Font size is a somewhat personal thing and everyone has a different opinion about adding, potentially, many hundreds of extra configuration settings to change font style without having to know the fundamentals of HTML, CSS or webcraft. The font sizes used in Kunena are based on the font size of the Joomla site template and (in many cases) they may appear a little smaller than how the text finally renders after a forum message is posted.
Based on what is written in this topic - and verified using web design tools such as Firebug (an add-on for Firefox) which, in my opinion, is something that everyone should equip themselves with and learn how to use - you need to add the following three lines to the end of your Joomla site template:
- Acidrainopg
