Question [RESOLVED] Font size in message editor is too small; users cannot read it
15 years 1 week ago #97075 by sozzled
Thanks, cdawolf. I probably should start a separate topic with the subject "10 good reasons why people should never try to directly edit the kunena.forum-min.css file".
Yes, people can change this file, if they want, and it may work ... or it may not ...
14 years 11 months ago #99719 by Mantaii
I have put the code in to my template.css file but it doesnt seem to work, any suggestions?
The code I have put in to my Joomla 1.6 template file is
#Kunena table#kpostmessage .ktxtarea {
border: 1px solid #BFC3C6;
font-size: 14px;
height: 200px;
overflow: auto;
14 years 11 months ago - 14 years 11 months ago #99721 by sozzled
The reason that the technique did not work for you may depend on several factors. For example, you may need to clear your browser cache to see the result. This is one of those "how long is a piece of string" topics; the answer depends on how long you cut the string, what kind of scissors you used, etc. Likewise, the reasons that things may or may not work for you may depend on your environment (e.g. which CSS files are loaded and in what order and what browser you are using and screen resolution, etc.). Sometimes the answer given to one person is not right for another person.
The correct answer, in all cases, is to look at the information given in the frequently asked question How do I change the colours of my template in Kunena?
We can tell you which file you need to modify if you post the URL of your website.
Last edit: 14 years 11 months ago by sozzled.
14 years 11 months ago #100469 by MyWorld
Replied by MyWorld on topic Text Editor Font Too Small
I'm probably the only blind bat around :laugh: but the font is too small in the text editor. Can it be increased? I would like to know how to change it on the forum I'm installing as well.
Thanks!!
14 years 11 months ago - 14 years 11 months ago #100496 by yuzef
If i may say : that you can change the size of text editor font by modifying your /components/com_kunena/template/default/css/kunena.forum-min.css
Find the code :
#Kunena textarea, #Kunena textarea.kmedium { font-size: 1em; height: 10em; width: 95%;
Change it to :
#Kunena textarea, #Kunena textarea.kmedium { font-size: 1.5em; height: 10em; width: 95%;
see the changed size : i use font-size: 1.5em; <--- this fit with me.. of course you can set what fit size for you.
hope that will work for you
Love Simplicty
read...... and learn........
My Joomla Test Site
Last edit: 14 years 11 months ago by yuzef.
14 years 11 months ago #100550 by MyWorld
Thank you yuzef!!
Time to create page: 0.270 seconds
