Question [Merged topic] Kunena Notice: Menu item /forum (Itemid=nnn) does not have Kunena Menu
15 years 11 months ago #65792 by bwkeyboardman
sozzled wrote:
You may also need to ensure that use the option Kunena Forum » Create Menu.
One of the things that the Create Menu feature does, is to create a module (see image below):
This worked for me. Thanks!
BW
15 years 11 months ago #65830 by sozzled
P4rD0nM3: see PM
bwkeyboardman: I'm glad. It seems such a trivial, unimportant thing. In most cases (in every case that I've encountered on my own sites) one doesn't need to do this; the installation process does it for you ... but sometimes it seems that it doesn't.
So, maybe we need to spell this out in plain English somewhere? B)
If you don't have a Kunena menu on your website, the first thing you should try is backend option Kunena Forum » Create Menu
15 years 11 months ago #65967 by Haddewade
sozzled wrote: This issue is solved (in 1.6.0). The solution just isn't properly explained. That's the difference.
We're sorry that the documentation we've written on the subject isn't easy enough to understand. We're sorry that a lot of people seem to be having difficulty understanding just how easy it is to establish a Kunena menu.
Thanks, this worked for me. Thumbs up!!
15 years 10 months ago #67018 by Blogmudgeon
Installed Kunena 1.6.1-DEV | 2010-10-12 | 3689 [ Timu ] about a week ago. Used the J! Main Menu manager to put a link to Kunena Entry Page for access to the forum. Works fine. Added all categories. All the tabs were present at the top of the forum--and no errors. Life looked good. And then today, I made the first post. Now I am making this post...:laugh:
All of the tabs disappeared--as described in many posts before. Where all of the tab pointers existed as menu items in the J! Kunena Menu created on installation--there was now nothing. The Menu was empty of any entries. Attempts to recreate them in the Kunena Menu did not restore the tabs at the top of the forum. Using the Main Menu manager to create links in the main menu results in this error code (I had this frustrating issue before about a week ago):
XML Parsing Error at 1:832. Error 4: not well-formed (invalid token)
The page that is asked for does display properly, albeit with the error code and no restoration of the tab at the head of the forum.
This appears for any menu item created. So, I follow the instructions here. Create Kunena Menu items in the Kunena Menu of the manager. Create identical menu item in Main Menu--and couple to "Default Menu Item" of the Kunena Menu that was created previously. Result--page displays properly, and no error code is displayed.
Still no tabbed menu at the top of the forum. Was this series of "fixes" supposed to restore them, or is this just a workaround to restore functionality through the main menu?
Also, could someone PM me a later release of the DEV build and I can see if this restores the tab menu?
TNX!
73 de Patrick
Joomla! 1.5.22
JomSocial 1.8.11
Kunena 1.6.1
EasyBlog 1.1.116
15 years 10 months ago - 15 years 10 months ago #67087 by colinwebster
Replied by colinwebster on topic Error since upgrade
Hi, I get the following error after the upgrade to 1.6
Can anyone help to resolve this ??
Last edit: 15 years 10 months ago by colinwebster.
15 years 10 months ago #67101 by xillibit
Replied by xillibit on topic Error since upgrade
This issue has been discussed many time, you can start by read this : www.kunena.com/forum/168-k-16-support/63...-index-recent-topics
You can read this topic :http://www.kunena.com/forum/168-k-16-support/63703-merged-topic-kunena-notice-menu-item-forum-itemidnnn-does-not-have-kunena-menu
Time to create page: 0.341 seconds
