- Thank you received: 7
Solved [Resolved] Posts on forum disappear!
we had the same problem of empty posts in some cases where links are included. We found the post of Ardenlyn here and the "shorten url" feature caused our problem too. Crazy, but the same site copied to my local xampp or a second local machine with lampp worked fine. :huh:
I have analysed this on our live server (FreeBSD) and I found the preg_replace() inside KunenaBBCodeInterpreter::PostProcessing() runs in a PREG_BACKTRACK_LIMIT_ERROR (get by preg_last_error()). So my first idea was to assign the replace result to a local variable and check last error before replacing original text.
But additionally I found the cause of the error: it's the "\3?" inside the search pattern. I have replaced this by "(http(s?)
/\/)?" which doesn't change the meaning but makes preg_replace() happy. We are using Joomla! 1.7.3 and Kunena 1.7.1, xampp has PHP 5.3.1 but lampp and our live server have running PHP 5.3.8.
Another little thing inside the same file:
In 1.7.1 you (the developers) have added "index.php" two times to a regular expression. Because you mean the concrete character "." you should escape it. Actually e.g. "index4php" would match too.
(sorry, if this is the wrong place to tell such things)
Best regards,
Hoffi
--ja
jabbott wrote: This fixed it for me too! Thanks!
--ja
What?
