Solved [Resolved] Posts on forum disappear!
Imagine a forum when some messages .. go away.
I founded that messages only apparentely disappeared.. If I try to "quote" I can see the original message, but NOT on the forum.. It is terrible
I try to upload to kunena 1.7, but nothing has changed... i'm really deasperate.. i'm not really sure if is a template problem..
Anyway i changed template, but nothing...
When you edit the blank message what do you see ?
This is the code of the invisible message..
And this is the code for a visible message...
:silly:
