14 years 6 months ago #124117 by xoofx
Hi All,
I had a problem with User Profile that cannot be edited on my website. It turned out that the problem was coming from gantry (at least until version 3.2.19) feature called "Build Titles Spans" that was modifying the <h2>"Edit"</h2> link of Kunena, making it unusable.
In order to solve this, you need to modify the file /libraries/gantry/features/jstools.php
if ($gantry->get('buildspans-enabled')) { $modules = "['rt-block']"; $headers = "['h3','h2','h1']";
As Kunena is embed in a "rt-block", all <h1><h2><h3> will be modified.
So the solution is to modify the container to apply the buildspans-enabled, for example by applying it only to articles and modules:
if ($gantry->get('buildspans-enabled')) { $modules = "['rt-article', 'module-content']"; $headers = "['h3','h2','h1']";
The following user(s) said Thank You: Valkyria
14 years 6 months ago #124422 by Przemysllaw
Replied by Przemysllaw on topic Same Errors in my forum
Hi Everyone.
I have big problem with kunena 1.7 - please see:
www.glucholazyonline.com.pl/forum/Muzyka...rne-na-Opolszczyźnie
I not see editor:
If want upload new images - no see dialog menu:
Hide croll modul ( kategories) not wirks.
Images popup not working:
Please help me. Sorry for my english.
14 years 6 months ago #124423 by sozzled
G'day, Przemysław, and welcome to Kunena.
Please read msg #1 of this topic for all of the answers to your questions.
14 years 6 months ago #124483 by Kadijs
So i got one intresting problem..
I intall kunena 1.7.2 in Joomla 2.5.. intall tamplate for both - yt_framework..
everything work great and cool.. but about hour ago i see somthing different - smilies don't work, bbcode toolbar not work.. everything else is fine.. i even reinstall kunena - but nothing change.. even put back defoult template - and nothing change, so where can problem can be hide..
i will be glad hear answer as possible soon.. and ye.. sorry about my bad english gramatic..
14 years 6 months ago - 14 years 6 months ago #124486 by sozzled
The answer to your problem is to be found by reading the links contained in msg #1 of this topic. The problem is not caused by Kunena (and so uninistalling/re-installing Kunena will not help). The problem is caused by another Joomla extension that you are using on your site.
If the advice given in msg #1 of this topic does not work for you, use the approach mentioned elsewhere in this topic: When all else fails, try this .
14 years 6 months ago #124544 by pablispeed
hi all does not work the profile can not be edited, anyone knows that can be
Time to create page: 0.160 seconds
