14 years 8 months ago - 14 years 8 months ago #121158 by sozzled
blogizm: All the best advice, about what you need to do, is contained in the links in msg #1 of this topic.
Last edit: 14 years 8 months ago by sozzled.
14 years 7 months ago #121329 by arredoannunci
I have the same problem with my forum
no button to edit the profile works
how you solved it?
sorry for my English!
14 years 7 months ago #121359 by sozzled
G'day, arredoannunci, and welcome to Kunena.
If you have the same problem with your forum, then you should read msg #1 in this topic to find the answer.
14 years 7 months ago - 14 years 7 months ago #121375 by Isaiah53
Replied by Isaiah53 on topic Re: Post(Show) profile
I have just installed Kunena 1.7.2 on Joomla! 2.5.3 Stable. I and am also having a similar issue of not being able to "EDIT" the profile. The EDIT is there, but not able to click on and thus edit the profile.
Does anyone have a solution to this problem?
mimimike64 wrote: Bonjour,j'utilise joomla 1.5x et virtuemart 1.9 . kunena 1.72. Le bouton affiche le profil n'apparait pas. Il est donc impossible de modifier le profil d'un utilisateur ou d'ajouter des information. J'utilise un template Rokettheme. Merci pour la solution.
Hello, I use joomla 1.5x and virtuemart 1.9. Kunena 1.72. The button posts(shows) the profile does not appear. It is thus impossible to modify the profile of a user or to add information. I use a template Rokettheme. Thank you for the solution.
Last edit: 14 years 7 months ago by Isaiah53. Reason: forgot to add Joomla version
14 years 7 months ago - 14 years 7 months ago #121378 by sozzled
G'day, Isaiah53, and welcome to Kunena.
Please read msg #1 in this topic to find the solution to your problem.
The same goes for mimimike64 who posted a similar question over one month ago.
Last edit: 14 years 7 months ago by sozzled.
14 years 7 months ago - 14 years 7 months ago #121476 by yakman
I have tried to upload images via forum post and everytime you hit the add button it does nothing
I have tried this via regisetered user and super admin and nothing. I can creaton a article and add image thru the create of a article.
I also downloaded latest version hoping that would fix the problem but it didn't
I appreciate any direction or suggestion I am a little new
I have also checked all configs to make sure to allow upload
Last edit: 14 years 7 months ago by yakman.
Time to create page: 0.158 seconds
