14 years 7 months ago #121771 by fk97440
I tried to disable all modules/plugins the problem is still there. I tried to reinstall joomla and kunena without jv-framework, using the main template, same problem.
14 years 7 months ago - 14 years 7 months ago #121775 by sozzled
fk97440 wrote: I tried to disable all modules/plugins the problem is still there. I tried to reinstall joomla and kunena without jv-framework, using the main template, same problem.
I should probably write an article called "When all else fails, try this":
This is what I would write in my article:
(1) Create a completely new "vanilla-flavoured" Joomla test site (it doesn't matter if you use J! 1.5.26 or J! 2.5.4 for this test). On this test site, do not install anything else. Do not install any other templates, or extensions like sh404SEF or Community Builder for example.
(2) Using this test site, install K 1.7.2. Do not change any of the original configuration.
(3) With this very simple test site, I would like you to try the same test. Do you have your original problem on this test site? If everything works then you have found the answer to all of your problems. You now have a working website! :woohoo:
(4) One by one, change your test site by adding the other extensions you have on your problem site. After adding each extension, continue to test Kunena to make sure that you do not have any problems. Either you will find something that you've added which caused the problem (and then you can fix it up or remove it from your live site) or you won't. If you don't find the problem on your test site then (again) you now have a site that works! And then you can use this working site instead of the one that you've got problems with.
The first three steps should take you less than one hour.
Last edit: 14 years 7 months ago by sozzled.
14 years 7 months ago #121947 by fk97440
Hello sozzled, yesterday i changed joomla template (from jv framework jv melody to yougrid) and now the button works !!!
Unbelievable !!
I had tried to reinstall joomla without any more template and the button didn't work ! Now with this template it worls !
14 years 7 months ago #122516 by yakman
Replied by yakman on topic Lost My Boarcode
I changed templates with my new load of 1.7
I went from siteground-j15-1 to js_impacto template
I can't figure out why when I switch templates the boardcode you can't see
any suggestions would be helpful. What effects the boardcode?
14 years 7 months ago - 14 years 7 months ago #122520 by Helfgott
Replied by Helfgott on topic Cannot edit user profiles
Hi guys, i ran into a trouble with Kunena 1.7, i was able to edit users profile (avatar and stuff) but now i can't.
Recent changes
* Installed K2
* Enabled BT Slide Content
I found with firebug:
<div id="kprofile-edit">
<dl class="tabs">
<dt class="open">User Account</dt>
<dd style="display: none;"> :(
<dt class="closed">blbalblabla</dt>
<dt class="closed">Image - Avatar</dt>
<dt class="closed">forum options...</dt>
</dl>
When user is logged in, the css don't change so the user is unable to change his profile, obviously enabling display:block with firebug works and let change the avatar.
Any idea? tx in advance.
Last edit: 14 years 7 months ago by Helfgott.
14 years 7 months ago #122523 by sozzled
yakman: please read msg #1 of this topic for the answer.
Time to create page: 0.163 seconds
