14 years 7 months ago - 14 years 7 months ago #121499 by sozzled
You posted your question in the General Talk about Kunena category. I see that you last posted on this forum about two years ago. Welcome back.
Not being able to attach images on forum posts could be caused by a lot of things but, when you say that "every time you hit the add button it does nothing" I think you have a Javascript library conflict. I am considering that this is probably the likeliest reason because you were using a very old version of Kunena when you last wrote to us and, as you say, you "downloaded the latest version hoping that would fix the problem". The question is, did you read the upgrade guide before you installed "the latest version"?
Suggestions:
(1) Read msg #1 of If you are having problems with Kunena, please read this first
(2) Post your K 1.7 configuration report
(3) Please do not wait another two years before you reply. I responded quickly to your question; it will help us everyone if we keep to a fast response turnaround. Thanks.
The General Talk about Kunena category description states:
Please use other categories for support questions.
This category is for general discussion about Kunena, feedback and your suggestions about how to improve the service to the Kunena community.
I will move this topic to a more appropriate category when I have read your reply.
Last edit: 14 years 7 months ago by sozzled.
The following user(s) said Thank You: yakman
14 years 7 months ago #121509 by yakman
thank you for your help
I have narrowed it down to the template. If I switch the site template the problem goes away.
So actually nothing to do with the forum
14 years 7 months ago #121513 by sozzled
14 years 7 months ago #121716 by fk97440
one month later..... up ?
14 years 7 months ago #121720 by Admata
Try to enable Joomla 'System - Mootools Upgrade' plugin ;)
14 years 7 months ago #121765 by sozzled
You cannot "enable" the System - Mootools Upgrade plugin in J! 2.5.1 because there is no such thing in J! 2.5.x.
Nonetheless, the problem is the same as the issues referred to in msg #1 of this topic. There is a Javascript library conflict caused by something loaded by another Joomla extension on the problem site (but I don't know white one it is). I would discuss your issue with the people who developed the jv-framework template; ask them if their template works with K 1.7.2.
Time to create page: 0.153 seconds
