15 years 1 month ago #108164 by dmalone91
I am new to the Kunena extension, so forgive me for being completely dumb. I am using joomla 1.7 and I just added the Kunena forum. However, when I enable my Jfinalizer, I no longer have access to my Boardcode when trying to add a new topic to the forum. Is there any way I can have both? or is there a similar plugin like Jfinalizer that may be better? Because without Jfinalizer my site is EXTREMELY slow, and i have no idea how to fix this issue.
Also, for some reason my kunena menu items seem to be mis placed, for exaple the emoticons are grouped to the right while their selection buttons are all grouped to the left. Any idea how to fix this?
You can view my site at: techyouverymuch.com/
or the forum at: techyouverymuch.com/index.php/forumindex.html
any help would be appreciated.
Thanks,
Daniel
15 years 1 month ago #108197 by xillibit
I'am not able to access to your site, it's load during a couple of minutes then i have an error 500. Actually, do you have Jfinalizer enabled ?
Can-you put here please your Kunena report configuration ?
15 years 1 month ago - 15 years 1 month ago #108202 by xillibit
Replied by xillibit on topic Re: Can't upload pictures
You have an issue with Mootools on your site, actually the version 1.12 is loaded by something :
<script type="text/javascript" src="/community/media/system/js/mootools.js"></script>
, but for Kunena you need to have Mootools 1.2.4 at least.
Last edit: 15 years 1 month ago by xillibit.
15 years 1 month ago #108210 by dmalone91
Yes, Jfinalizer is enabled, and it seems to be what is causeing so many issues with my site, Although, i could be completely mistaken.
this is my kunena full report:
hope this helps
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 8M
Joomla default template details : as002031 | author: AS Designing | version: 1.0.0 | creationdate: 09-07-2011
15 years 1 month ago #108220 by xillibit
Can-you start by disabling Jfinalizer ?
15 years 1 month ago #108221 by dmalone91
Yeah, it comes back when I disable it. Is there a way to get it to work with it enabled? But even when it is disabled the alignment is way off.
I only use jfinalizer to speed up my site. I'd gladly uninstall it if I knew another way to speed up my site. And as you have seen, even with jfinalizer it is still overly slow. So idk what to do.
Time to create page: 0.173 seconds
