15 years 4 months ago #99262 by TBC
OK, read #1... using RocketThemes: disabled "Build Title Spans", Disabled RokBox system rokbox and content rokbox... still no profile functions. If my reading is correct it wouldn't be mootools as it's a brand new install of Joomla 1.6.
Thanks for the reference and any ideas?
15 years 4 months ago - 15 years 4 months ago #99264 by sozzled
TBC wrote: ... a brand new install of Joomla 1.6.
Although it's somewhat unusual that other Joomla extension developers' products should clobber the standard Joomla 1.6 Javascript library with their own software, it's not unheard-of, either. If, indeed, your site is a "brand new installation of J! 1.6" (i.e. without any other extensions loaded) then you should not encounter such problems with Kunena. On the other hand, the situation may not be a case of "a brand new installation of Joomla" but more a case of Which came first? The template or the forum?
Indeed, your problem may not even be Mootools-related but could be affected by the version of Joomla that you have installed.
Last edit: 15 years 4 months ago by sozzled.
The following user(s) said Thank You: TBC
15 years 4 months ago - 15 years 4 months ago #99271 by TBC
Thanks, read the thread, it makes good sense and to be honest... that's about what I did. Installed a clean version of Joomla (simple scripts a week or so ago), istalled the rocket themes template and did some simple modifications to make it look like the demo, and came here to get a fresh copy of Kunena for 1.6.
Didn't want to add any bling until I had the desired appearance and core functionality.
I guess I'll go through and disable everything that I can to see if I can isolate a plugin or component that may be creating the issue but really don't want to start from scratch with the Joomla install and template modifications.
Thanks again for your help and I'll report back if I find anything, and will check back to see if others have any ideas.
Joomla Version 1.6.3
Kunena Version 1.6.4
RocketThemes Modulus Template Version 1.6.1
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : rt_modulus_j16 | author: RocketTheme, LLC | version: 1.6.2 | creationdate: June 22, 2011
Last edit: 15 years 4 months ago by TBC.
15 years 4 months ago - 15 years 4 months ago #99306 by dobledosis
Hi all, im using Joomla 1.5.23 Stable with Kunena Latest 1.6.4 and Mootools 1.2.5
The first problem i have is that i cant see correctly the Boardcode options as you can see in the image:
The second problem is that i cant acces the user profile editor:
I hope you can help me. Thanks!
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 200M
Joomla default template details : fnx_th2 | author: | version: 1.0 | creationdate: 2011-06-26
Kunena default template details : FNX | author: FNX Team | version: 1.6.4 | creationdate: 2011-05-07
Modules: Kunena Latest 1.6.4
Last edit: 15 years 4 months ago by dobledosis.
15 years 4 months ago #99314 by sozzled
G'day, dobledosis, and welcome to Kunena.
Both of your problems are caused by the same issue. See msg #1 in this topic for the answer.
15 years 4 months ago - 15 years 4 months ago #99325 by chgeiselmann
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 150M | Max file upload: 20M
Joomla default template details : Formig | author: Christian Geiselmann | version: 3.0 | creationdate: 15.05.2010
Dear all,
I have Kunena 1.6.4 running on a Joomla 1.5.23 and a Joomla 1.5.22 system.
One of my various problems with Kunena is: User cannot edit their profiles when they use firefox.
As long as they use IE, everything works with the user profile editing. However, in Firefox, it doesn't. On clicking the "edit" button, the expected tabs appear (User account, Profile info, Avater, and the like), but they do not react on clicking them. Neither the picture-upload field does show any reaction. Moreover, the sections in the lower part of the profile window are not rendered completely: Were in IE there is a table showing recent contributions of the respective user, nothing is displayed in Firefox.
More information [edit]: Similarly, the bbcode icons are not displayed in Firefox. In IE, they are!
How can this be solved?
Thanks, kind regards,
Last edit: 15 years 4 months ago by chgeiselmann. Reason: Infornation added
Time to create page: 0.217 seconds
