Sticky Change the "default view" of the forum from Recent Topics to Index
Also any tips on having the forums show up full page instead of staying in the frame of the theme?
check it out if you can and let me know what you think I can do to fix the above 2 questions
www.rocksmithnation.com
can you please detail this for me because its not very clear and forwarding me to the FAQ did not enable me to fix this. im confused.
How do I change the "default view" of the forum from Recent Topics to Index?
Go to Kunena Menu (in Joomla Menu Manager) and change the first entry. There's option that allows you to select a different the default "entry" page.
I see no such option when i open Kunena Menu. is it in the configuration, Kunena Control Panel
Forum Configuration
Category Manager
User Manager
Template Manager
Emoticon Manager
Rank Manager
Uploaded Files Browser
Uploaded Images Browser
Prune Categories
Synchronize Users
Recount Category
Statistics
Trash Manager
General Statistics
Report Configuration Settings
Support Web Site ?
which tab? and what do i do?
And, by the way, please avoid using all capitals in the topic subject. Thank you.
they said
I read a prior post in the common questions of this forum, but it must be outdated as the reply did not work for me.
How do I set Kunena for forum to open with the index as default?
Moderator's comment: The message numbering may be different depending on who is viewing the topic. In this case we were referring to "msg #52" was posted by Vi3tShugo.
when i click the Joomla Menu manager and click Kunena It gives a bunch of catagories, there is now way to select a different entry page.
