Sticky Change the "default view" of the forum from Recent Topics to Index
15 years 4 months ago - 15 years 4 months ago #98708 by coscho
Hi Sozzled
First Thank You for your great component.
Now the problem. :P
1. I had change Default Menu Item to "- Index". I had make it Default Home Page BUT now url looks like domain.com/forum/categories . I want to looks like domain.com . I's a way to do this?
2. I had change Default Menu Item to "- Forum"(main kunena menu forum). Now is OK (looks like domain.com ) but the default menu item is "Recent topics". How can i change it to "Index"???
Thank you.
[solved]
Kunena Menu-Forum-(default item)'Index' very easy. :P
Last edit: 15 years 4 months ago by coscho.
15 years 3 months ago #99916 by joopyjoops
The default home page for my website is: mainlymanly.com.au/forum (if you type mainlymanly.com.au it will redirect to the forum).
However, if you go to bookmark the page or share it on facebook, the description of the page that comes up reads "Categories - Mainly Manly". I would like it to just read "Mainly Manly".
Where do i go to change this?
15 years 3 months ago - 15 years 3 months ago #99917 by sozzled
Fairly simple and this topic deals with the subject. The topic is given more coverage in Customised menus and I suggest that you read it. I hope that helps.
When you write "I would like it to just read 'Mainly Manly'" what is the "it" we are discussing; are describing the browser window title, or something else? For example, is there something here (at www.kunena.org ) that illustrates what you're trying to achieve?
Last edit: 15 years 3 months ago by sozzled.
15 years 2 months ago #105361 by Jungalist81
Hello community of Kuena,
I am trying to find a way to make the forums display the Index instead of the recent topics. Every-time my users click on my forum link, they get sent to the recent topics. How do I change that?
Let me know if I need to be more specific. Thanks
Jungalist81
15 years 2 months ago #105368 by Matias
You need to change first menu item (Forum) from Kunena Menu. It has a field that defines default page (points to another menu item).
15 years 2 months ago #105584 by Jungalist81
"Go to Kunena Menu (in Joomla menu manager) and change the first entry. There's selection that allows you to pick up the default page."
I am confused to what the "first entry" is and the selection is.
The Kuena forum is broken up into categories such as Forum Configuration, Category Manager, Forum Manager, emoticons, etc. Is this the "first entry" you speak of?
