Sticky Change the "default view" of the forum from Recent Topics to Index
Currently using - 1.7.3 Joomla with latest Kunena
1.) Login to Joomla Admin Control Panel
2.) Click on the "Menus" Tab at the top and select "Kunena Menu"
3.) Click on the menu item called "Forum"
4.) Look to the right and click on "Required Settings"
- It should expand and show "Default Menu Item *"
5.) Click on the drop down menu and click "Index" or whichever you want to be the default.
6.) Save & Close
The names of the items might vary if you've changed them, but that's the general idea.
And in the text area some of my buttons such as edit, quoto are invisible. So my users cannot edit their posts. How can i solve it. Picture below
http://imageshack.us/photo/my-images/36/19222589.png/
kunena 1.7.2
Joomla! 1.5.23
I read a prior post in the common questions of this forum, but it must be outdated as the reply did not work for me.
How do I set Kunena for forum to open with the index as default?
[strike]How can I set it for "forum statistics" section not to show in the front-end, **whether the user is registered or not** ?[/strike]
These are commonly-asked questions. It helps if you search the forum for the answers and to read the FAQs (see the menu item above the forum).
I have merged your topic with another one that has the answer to your question.
