- Thank you received: 566
Question Change the "default view" of the forum from Recent Topics to Index
- Jungalist81
I am confused to what the "first entry" is and the selection is.
The Kuena forum is broken up into categories such as Forum Configuration, Category Manager, Forum Manager, emoticons, etc. Is this the "first entry" you speak of?
So go to menu manager and select "Kunena Menu". Then open the first item called "Forum" and in the right side you should see dropdown to select other menu items. Pick the one you want to use as default and save.
- Jungalist81
I have a suggestion Matias. I suggest to have it the Kuena default to displaying the index initially. Five pages worth of responses asking for "how to change from reccent topics to index" should warrant that dont you think?
I dont mean to offend, I only offer this suggestion simply because I love this plugin and I hope that this will be used by every Joomla owner. Thank you
- stevetyler
Also, where would I find where to change the tabs at the top, e.g. "rules", "help" etc.
G'day, Steve, and welcome to Kunena.stevetyler wrote: My new forum seems to revert to "recent posts" by default when first opening the forum whereas I would like it to simply go to the index with all categories displayed. I can't find an option to change this. Any ideas?
This is a fairly common question. The answer is in msg #2 of this topic. If you are having troubles with the menu, you should go to the Joomla Menu Manager and find your Forum item from it. Find the item that is of type "Kunena Forum » Entrypage", edit the item and change Default Menu Item to "- Index".
That's also a frequently asked question. The answer is given on the FAQs - click the menu tab at the top of the foum on this page and see under How do I edit, hide, disable or translate menu items in Kunena (e.g. rules, help, search)? .stevetyler wrote: Also, where would I find where to change the tabs at the top, e.g. "rules", "help" etc.
EDIT:
Never mind. I thought what I did didn't work, but it did. It just took a couple of site reloads in my browser. All is good!
Currently using - 1.7.3 Joomla with latest Kunena
1.) Login to Joomla Admin Control Panel
2.) Click on the "Menus" Tab at the top and select "Kunena Menu"
3.) Click on the menu item called "Forum"
4.) Look to the right and click on "Required Settings"
- It should expand and show "Default Menu Item *"
5.) Click on the drop down menu and click "Index" or whichever you want to be the default.
6.) Save & Close
The names of the items might vary if you've changed them, but that's the general idea.
