Kunena 7.0.8 Released
Question Collapse, expand and Emoticons dont work
15 years 11 months ago #61603
by fxstein
Replied by fxstein on topic Re: Collapse, expand and Emoticons dont work
Do you have a url to the Kunena install? Would like to have a look at it with FIrebug. Its probably a simple conflict that is causing your issues.
The following user(s) said Thank You: Fremesa
The topic has been locked.
15 years 11 months ago #61605
by Fremesa
Replied by Fremesa on topic Re: Collapse, expand and Emoticons dont work
15 years 11 months ago #61606
by fxstein
Ok - I see.
Looks like you are using some kind of a css and js compressor plugin for your site. Never had luck with any I have tried, and I feel there are better ways to accomplish the same thing - like installing a good component
Kunena already has minified css and js.
Aside from that I cannot tell the conflicts as multiple libraries have been munged together by that compressor.
Can you please disable that for now?
15 years 11 months ago - 15 years 11 months ago #61615
by Fremesa
Ok, i disable rokzip and motool... I disable the mtupgrade too, cause i see some errors, and appyed the defaul skin... but Know firebug sendme another diferent bug... check please.
PD: You have a awsome support... very faster.
Last edit: 15 years 11 months ago by Fremesa.
15 years 11 months ago #61617
by fxstein
Maybe its because this is not really support.
We are not a company. Its just the community helping each other. :lol:
Pay it forward... :lol:
Fremesa wrote: PD: You have a awsome support... very faster.
15 years 11 months ago #61618
by fxstein
Ok - That error:
Is expected if you disable MTUpgrade. The slimbox script is throwing that error, because mootools 1.2.x is missing.
Please enable MTUpgrade system plugin.
Thx!
Browser is not defined
Thx!
Time to create page: 0.235 seconds
