Question Collapse, expand and Emoticons dont work
16 years 3 weeks ago #61632
by Fremesa
Replied by Fremesa on topic Re: Collapse, expand and Emoticons dont work
disabled... but no fixed!!
The topic has been locked.
16 years 3 weeks ago #61634
by fxstein
Replied by fxstein on topic Re: Collapse, expand and Emoticons dont work
On the bright side, that should mean that none of these is causing it.
You templates loads several more js scripts:
cufon.js
domready_fix.js
gk.script.js
Can you disable those too?
cufon.js
domready_fix.js
gk.script.js
16 years 3 weeks ago #61635
Replied by sozzled on topic Re: Collapse, expand and Emoticons dont work
Well, I wouldn't go so far as to say that none of those disabled functions isn't responsible. I was reading, last night, about some of those JCE utilities (including the jcemediabox) and, unless you really, really need them I would put them high on my list of suspicious items.
There's another one I saw, too, that we haven't got yet: gkmemovie. Might be worth looking at that, too. Looks like that module/plugin loads another 3 .js libraries that I could tell.
The following user(s) said Thank You: Fremesa
16 years 3 weeks ago #61637
by Fremesa
cufon I disabled, but domready_fix.js gk.script.js I dont find. but i disable all templaste opcion... and nothin happen.
16 years 3 weeks ago #61639
by fxstein
Those scripts are most likely in the html of the template. Go to the Joomla template manager and check out the html file. It will have multiple includes for js in there.
Hope this helps!
Hope this helps!
16 years 3 weeks ago #61640
by Fremesa
Well... i goint to test memovie in my localhost... couse i made many change to my template... and nothing work fine... I goint to test if its the template or shome other think and i posted here de problem solved.
Thank You for all... read you later!!
