Question Collapse, expand and Emoticons dont work
16 years 3 weeks ago #61665
by Fremesa
Replied by Fremesa on topic Re: Collapse, expand and Emoticons dont work
The installation and provide some of the themplaste of Gavick and other JXTC and I had the same problem. In one I had not ...
From Gavick not operate any, available from people in a clean installation of themplaste memovie, Quay and the last of them cherry desing ... and might provide in Game JXTC and one that if it worked ...
I recommend that people talk Gavick.com to see what the problem between Kunene and his templastes.
If you somehow find the problem, respondanme this post to fix it, because my users use a lot of forums and could not go to the forum with such problems, since there is no second chance to make the first impression.
Thanks for everything!
The topic has been locked.
16 years 3 weeks ago - 16 years 3 weeks ago #61666
by Fremesa
Otra cosa, con no hay problema.
Another thing, with kunena 1.5.12 there is no problem
Last edit: 16 years 3 weeks ago by Fremesa.
16 years 3 weeks ago #61667
Replied by sozzled on topic Re: Collapse, expand and Emoticons dont work
If you are saying that K 1.5.12 doesn't cause you any problems, that's to be expected because K 1.5.12 doesn't use the Mootools 1.2.4 Javascript library. Therefore, anything that you have installed, that messes up the Mootools 1.2.4 library - and you have something that's doing that - will not affect K 1.5.12.
You haven't solved your problem. You've just postponed it.
16 years 3 weeks ago #61723
by Fremesa
Oh, Mootools is the problem... Kunena or Gavick developers???
Other think, the menu dropdown do not work if i have enable the mtupgrade.
I have a Nice kunena 1.6 template ready, but i think i have to downgrade to Kunena 1.5...
16 years 3 weeks ago - 16 years 3 weeks ago #61836
by WaoX
Replied by WaoX on topic Re: Collapse, expand and Emoticons dont work
I have exactly the same problem.
www.toidukohad.eu/test4
Didn't have that problem with Kunena 1.5.x
Sorry´, my bad.
I didn't publish Mootools upgrade. Now it works
Great job!
Sorry´, my bad.
Great job!
Last edit: 16 years 3 weeks ago by WaoX.
- mountain91074
15 years 6 months ago #90031
by mountain91074
Replied by mountain91074 on topic Re: Collapse, expand and Emoticons dont work
Have you enabled mootools upgrade plugin?
