Kunena 7.0.8 Released
Question Collapse, expand and Emoticons dont work
15 years 11 months ago - 15 years 11 months ago #61585 by Fremesa
Hello!
Im new working with kunena... i just work with Invision Power Board, but the integration Kunena-Joomla is very interesting for me.
I installed Kunena 6rc2, but i have problem in my website. The collapse/Expand do not work and went i click in the emoticons nothing happen.
I using the GK memovie Templaste from Gavick Pro, and in tested with diferents Kunena Templaste to.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 8M
Third-party components: AlphaUserPoints: Enabled (Version : 1.5.11) | CommunityBuilder: Disabled or not installed | Jomsocial: Enabled (Version : 1.8.8) | UddeIm: Disabled or not installed
Last edit: 15 years 11 months ago by Fremesa. Reason: fixing my kunena version
The topic has been locked.
15 years 11 months ago #61589 by xillibit
What browser do you using ?
Please enable the plugin mtupgrade in your Joomla! plugin manager.
15 years 11 months ago #61595 by Fremesa
Defaul Browser Firefox 3.6... but i always test first in Opera, IE8, Safary and Chrome
I enabled the plugin, but its not working yet.
15 years 11 months ago #61597 by Fremesa
Quick reply dont work eather
15 years 11 months ago #61600 by Fremesa
FireBug Report Just in the Forum.
Image attachment!!
15 years 11 months ago #61602 by fxstein
SInce you are getting errors from jcemediabox, I would definitely recommend disabling it to see it that is causing the issues. You should not see any errors from any components or modules you install.
The following user(s) said Thank You: Fremesa
Time to create page: 0.286 seconds
