Question system cache plugin + Kunena
15 years 11 months ago #77944 by sozzled
I only know two things:
(1) I am assuming that the "Page Cache" plugin that you are referring to is the Joomla System - Cache plugin. The System - Cache plugin is disabled in Joomla by default. I don't know what the Joomla System - Cache plugin does.
(2) Kunena has been tested by ordinary people under a variety of conditions for use with Joomla. I have not seen reports of problems in ways that you have enquired about.
You can find out more about the System - Cache plugin by visiting the Joomla website and asking questions at forum.joomla.org
15 years 11 months ago #78171 by prophoto
Could you forward this message to the Devs? I'd really like a bit of clarification. There has to be somebody who knows how it works in relation to Kunena!! Thank you.
15 years 11 months ago #78214 by sozzled
The only clarification I can provide you, at the present time, is that the System - Cache plugin - I assume this is the plugin you are referring to (you haven't said that it is) - is
(1) not enabled by default in Joomla;
(2) not enabled at www.kunena.org ;
(3) not enabled in any website that I am familiar with;
(4) according to the book Using Joomla by Ron Severdia and Kenneth Crowder, published by O'Reilly Media (2009), "this plugin facilitates the functionality involved in the caching feature within Joomla";
(5) there is a lot of information about the System - Cache plugin at the Joomla website, for example forum.joomla.org/viewtopic.php?f=432&t=319565
(6) as far as we are aware, the System - Cache plugin has no other detrimental effect on Kunena than on any other Joomla extension.
If people are aware of specific issues involving the System - Cache plugin and Kunena we would be most interested to hear about them.
15 years 11 months ago #78244 by prophoto
Yes, system cache plugin (see initial post and title). There are actually a few caching methods in Joomla, system cache plugin (for page caching) is one that everybody forgets about and they only rely on the view cache turned on in the global config.
I am testing and will report findings.
11 years 10 months ago #161465 by Josh
Replied by Josh on topic system cache plugin + Kunena
Any update on this? Seems that Kunena does not play nice with the system plugin on Joomla 3.3.6.
11 years 10 months ago #161474 by 810
Replied by 810 on topic system cache plugin + Kunena
system cache plugin, is created for static sites, so if you have a website that is changing then you should disable the plugin.
