Question system cache plugin + Kunena
11 years 10 months ago - 11 years 10 months ago #161480 by sozzled
Josh wrote: Any update on this? Seems that Kunena does not play nice with the system plugin on Joomla 3.3.6.
This topic is over four years old and relates to issues involving J! 1.5. The J! 1.5 system cache plugin behaviour was very different to the current J! 3.x behaviour.
As 810 hinted, if your website content is changing very dynamically—if content is altered many times a minute, for example—you may want to consider disabling the Joomla system cache plugin. If the content on your website is relatively static, you might prefer to enable the Joomla system cache plugin. The choice between enabling or disabling the plugin really is something to be decided on a case-by-case basis.
Last edit: 11 years 10 months ago by sozzled.
11 years 10 months ago #161497 by Josh
Replied by Josh on topic system cache plugin + Kunena
My site is going to be a wiki site, so yes it's going to be dynamic. However I have the cache plugin only visible to guest users so that logged in members can see content in real time. Yes this is a slight inconvenience to guest viewers but not much of one. The site speed boost will help encourage site contributions as well as help with SEO.
11 years 10 months ago - 11 years 10 months ago #161498 by sozzled
Josh wrote: Seems that Kunena does not play nice with the system plugin on Joomla 3.3.6.
Could you please explain what you mean by your suggestion that Kunena "does not place nicely" with the System - Cache plugin in J! 3.3.6?
11 years 10 months ago #161499 by Josh
The layout is broken and I get an error message as seen here . The error message says:
0 - DateTime::__construct(): Failed to parse time string ({"year":"1977","month":"7","day":"2"}) at position 0 ({): Unexpected character
It only does this inside of the topic. The index, categories, and search display just fine. I confirmed that this is not a template conflict.
11 years 10 months ago - 11 years 10 months ago #161501 by sozzled
Does this error disappear if you disable the Joomla System - Cache plugin?
It looks, to me, that this error is not coming from the Kunena component ... but I could be wrong.
11 years 10 months ago #161502 by Josh
The error disappears when the plugin is disabled. I knew this before posting. What I'm proposing "is it possible for Kunena in the future to ignore the plugin completely?". This way we can cache Joomla articles and use Kunena.
