Question system cache plugin + Kunena
15 years 11 months ago #77416 by prophoto
Does anyone use the system cache plugin with Kunena? My forum is getting a lot of hits and users have mentioned the site is slow sometimes. The hosting is on a dedicated server - not shared hosting so resources are not an issue. Does it cause any problems? Other concerns? Does it help at all for either logged in users or guests?
Any thoughts would be appreciated.
15 years 11 months ago #77818 by prophoto
Bump.
15 years 11 months ago #77820 by sozzled
FYI The System - Cache plugin is not enabled here at Kunena.org.
15 years 11 months ago #77821 by prophoto
Can you help with my other questions?
15 years 11 months ago - 15 years 11 months ago #77824 by sozzled
I'm sorry. What other questions are these? I've mentioned the information for what it's worth. You asked if other users have had issues with the System - Cache plugin. The plugin is normally disabled by default in J! 1.5.x I haven't encountered these issues. I do not normally change Joomla default settings.
The only thing I can tell you, as far as this particular issue is concerned, is that this website www.kunena.org does not have the System - Cache plugin enabled. Do you encounter any difficulties when you use this website www.kunena.org :dry:
Last edit: 15 years 11 months ago by sozzled.
15 years 11 months ago #77832 by prophoto
My apologies, I should have asked more questions. Is Kunena designed to work with the Page Cache Plugin? Does it cause any problems? Does it help at all for either logged in users or guests? What other items impact the speed of Kunena?
