Question system cache plugin + Kunena
I'm guessing that this error message is generated either:
a) part-way through the loading of the topic; or
b) after Kunena has finished processing and Joomla is attempting to load other parts on the page.
In either case, the disturbing factor is that the CSS stylesheet is not properly loading.
To better understand what's going on, the first thing to do is to enable Joomla debug mode and follow the trace-back to see which file is being used at the point when the error message appears.
I'm flying blind here because I don't know much about your website. Even if I saw your Kunena configuration report, I am not sure if I can "remotely diagnose" the problem here, on this forum. I'm willing to give it my best shot, however, but I would be very surprised if the System - Cache plugin was the only thing responsible for this problem.
For your information, I rarely enable the System - Cache plugin—not because I distrust it or fear that it will cause problems but simply because I have no use for it in my websites.
I will enable this plugin on a test site and confirm if K 3.0.6 fails to load pages like it does on your site ... and I will report back soon.
J! 3.3.3 (too many problems with J! 3.3.4, J! 3.3.5 and J! 3.3.6 and I will not be updating Joomla until those problems have [hopefully] been fixed in J! 3.4.0)
K 3.0.6
Joomla Protostar template
Kunena Blue Eagle template
Joomla System - Cache plugin enabled
Global Configuration » System » Cache Settings » Cache = OFF - Caching Disabled
Global Configuration » System » Cache Settings » Cache Hander = File
Global Configuration » System » Cache Settings » Cache Time = 15
No problems detected when viewing categories, topics or posts in topics.
I don't know if this helps or not.
1) Global Configuration » System » Cache Settings » Cache = ON - Conservative caching
2) Global Configuration » System » Cache Settings » Cache = ON - Progressive caching
In both cases, no problems.
