Sticky How to implement Search Engine Optimisation - SEO - in Joomla
14 years 9 months ago #119143 by GoremanX
What you want should be the default if you turn on both the Joomla Search Engine Friendly URLs and the Kunena Search Engine Friendly URLs. This is assuming you're not using any 3rd party SEO extensions. Also, your menu items need to be organized properly for this to work. Ideally, your Kunena Configuration Report would give us a better idea of what might be misconfigured on your site. See the instructions at the top of this page for more information.
www.friendlyphotozone.com
14 years 8 months ago #120858 by gyounger1
Replied by gyounger1 on topic installing in /forum/
hi
im new here so apologies if this has been mentioned before.
I have installed Joomla 2.5.3 and Kunena 1.7.2
i have instlaled it in
/forum/index.php/forum
but can someone help me to change it so it says
/forum/
and also how to display the forum on the front page of the joomla site so when a visitors visits my site ie domain.co.uk they see the forum first
many thanks
14 years 8 months ago - 14 years 8 months ago #120868 by sozzled
G'day, gyounger1, and welcome to Kunena.
The answer to your first question is to read Search Engine Optimisation (SEO) in the Wiki and implement accordingly.
The answer to your second question is to make the forum menu item in your main menu the default one; see How to make Kunena menu item the "default" one?
Last edit: 14 years 8 months ago by sozzled.
14 years 8 months ago - 14 years 8 months ago #121263 by krebsinfo
When the URL ist part of joomla the error site 404.html is working when the URL is not compleat or wrong, when the URL beginns with an KUNEA link and ends wrong... " www.stoma-ok.at/index.php/forum-2/ind (...last part is missing), this 404.html is not called. Then i only get the Error-message from the appache-server "404 - Kunena function "ind" not found"
How can i fix this problem?
Last edit: 14 years 8 months ago by krebsinfo.
14 years 8 months ago #121271 by sozzled
krebsinfo: I suggest that you read Search Engine Optimisation (SEO) in the Wiki and implement accordingly.
14 years 7 months ago #122986 by contender
Replied by contender on topic mod_rewrite?
running Joomla 2.5 and want to install K 1.7.2
In the install guide, one of the requirements is to implement Joomla SEO.
docs.kunena.org/index.php/Search_engine_optimization_%28SEO%29
On step 2, it saids I have to select Yes of Use Apache mod_rewrite.
On my backend, I don't see a "Use Apache mod_rewrite". Instead, I see a "Use URL Rewriting", which also requires htaccess.txt to be renamed to .htaccess.
Is "Use Apache mod_rewrite" and "Use URL Rewriting" the same thing when it comes to Joomla 2.5?
Thank you
