Sticky How to implement Search Engine Optimisation - SEO - in Joomla
14 years 10 months ago #114706 by sozzled
Replied by sozzled on topic Re: Problem with Joomla SEF
Easiest way to unravel the "mystery" about Joomla SEO is to follow the advice in Search Engine Optimisation (SEO) .
14 years 10 months ago #114710 by sozzled
I have updated Search Engine Optimisation (SEO) with further information that is relevant to K 1.7 and to the need to have a component menu item published on your site in order to make Kunena use Joomla SEF URLs.
14 years 10 months ago #115089 by AngelMR87
i cant post because i have my SEO setting in my global configuration set to yes but if i set everything to NO im able to post. but i need my SEO Setting set to Yes what can i do?
my forum
www.mireggaeton.com/reggaeton/forum/index.html
14 years 10 months ago #115090 by AngelMR87
Replied by AngelMR87 on topic help
my forum
14 years 10 months ago #115656 by andres
I've got a running Joomla 1.5.25 site with all the 3 SEO options enabled; I' would like to add a forum using Kunena to this site, but from what I've read :
SEO Settings->Add suffix to URLs MUST be set to NO
considering that it's not really possible to change this setting (the site has thousands pages, and it should need thousands of 301 redirects), is there a way to make Kunena 1.7.1 work with suffix URLs enabled?
If NO, is this a problem that is going to be fixed with Kunena 2.0 or no?
thanks in advance
14 years 10 months ago #115660 by Matias
No, the above setting has no effect to Kunena. Updated above document not to have that setting in it.
Time to create page: 0.155 seconds
