Question Problem with New Post Indicator
It was not possible to copy the selected file.
JInstaller::install: Failed to copy file: /var/www/vhosts/damsels.org/httpdocs/tmp/install_4ba0b7ba2c80b/site/class.kunena.php to /var/www/vhosts/damsels.org/httpdocs/components/com_kunena/class.kunena.php
Did you isolate the reason why you could not copy the selected file? Perhaps, for this reason, you have an incomplete or a corrupted version of Kunena and that is what is preventing the NEW! indicator from operating correctly?
BUT the New Posts function still does not work properly.
- CheechDogg
- Premium Member
So are you having the same problem as me, CheechDogg?
I have latest posts installed but what I really need is for the New! function to work properly.
You know damsella, I was actually having this problem and for some stupid reason I "did not" pay much attention to it when it was happening. I instead installed the latest kunena module and honestly "did not" pay much mind to it anymore. I know I have noticed this a couple of other times and as recent as 2 weeks ago.
Let me ask you a question, could the color of the font be the reason it doesn't display? I know I have done this before where I would edit the color of the font and that would prevent certain text from displaying properly.
Do you have an account we could use so we can check it out?
I wonder how many more people have this problem but have not posted about it?
damsella: Did you have any success, disabling all other modules on your website? Perhaps it's something to do with the Joomla template that you're using: what if you [temporarily, obviously] changed your site template to rhuk_milkyway to see if the vanishing "New" indicator syndrome persists?
Although this problem was asked in the Common Questions category, I would like to move it to the Support category because I think this is important to determine the cause.
And you are not running a standard Joomla template on this site, are you?
I will pm you a log in for my site. Once you are in, you will see the New! signs. Then change view, and they will disappear.
I have already conceded this point. Oscarfishlover and katiepeters have not responded to our requests for further information (perhaps they don't have any) or whether the symptoms are the same as yours. Let's move on, shall we?Well Oscarfishlover, and katiepeters, and cheechdogg all have the same problem as me.
damsella wrote:
I don't run Kunena.com. I am just a user here, like you. On those websites that I do manage, for some of them I use "standard" Joomla templates and for others, I don't. I am simply trying to eliminate anything extraneous to your situation.And you are not running a standard Joomla template on this site, are you?
damsella wrote:
Thank you. I am simply trying to analyse the situation and help as best as I can.I will pm you a log in for my site. Once you are in, you will see the New! signs. Then change view, and they will disappear.
Further, you mentioned something in your PM to me "Go to xxx and log in as yyy. You will need to try twice, but that is a whole other (Jomsocial) issue". I mean I'm beginning to suspect that there are other complexities conspiring to contribute to the cause: there's more to this than meets the eye.
The obvious way to eliminate all these other potential conflicts (and I want to stress the term potential) is for you to create a test Joomla site on your server, install nothing more than Kunena, create a couple of user accounts, make a test posting, and see if the "New" post indicator remains constant until you have actually read the topic ... which is the way that the Kunena "new" post indicator is supposed to work.
If the test operates, as I think it should, then we can rule out a problem with the base Kunena software. We cannot, however, rule out a conflict that something else is doing that affects Kunena operations.
The Jomsocial log in problem is a well known one on their website, not connected I think.
However, I will try to create a site with just Joomla and Kunena. But if I cannot have the New! function on Kunena if I am running any other software, that is a problem.
Thank you for all your time and attention on this.
ETA: vBulletin is just in a wrapper. It is not really on my Joomla site at all.
