- Thank you received: 566
Question IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
17 years 1 month ago #27389
by Matias
Replied by Matias on topic Re: IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
empty($file_ext) is true only if $file_ext is null, '' or 0. It is defined to be static (= keeps its value), so if block will get executed only once.
17 years 1 month ago #27474
by Ganzuelo
Replied by Ganzuelo on topic Re: IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
Matias can we get a copy of this whole code we need to fix.. I stink at php.. only good at copy and pasting in the set position?
17 years 1 month ago - 17 years 1 month ago #27475
by Matias
Jerry's code works, it may just show a notice for undefined variable (if notices are turned on).
The whole code looks like this:
/components/com_kunena/lib/kunena.parser.php lines: 340 ->
static $file_ext = null;
$matches = null;
if (empty($file_ext)) {
$params = &JComponentHelper::getParams( 'com_media' );
$file_ext = explode(',', $params->get('upload_extensions'));
preg_match('/\.([\w\d]+)$/', $between, $matches);
if (!in_array(strtolower($matches[1]), $file_ext)) break;
Last edit: 17 years 1 month ago by Matias.
17 years 1 month ago - 17 years 1 month ago #27477
by Ganzuelo
Its working now thanks!
Last edit: 17 years 1 month ago by Ganzuelo. Reason: reread and fixed..
- crisscross
- Junior Member
17 years 1 month ago - 17 years 1 month ago #27682
by crisscross
Replied by crisscross on topic Re:IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
I guess this version is supposed to break tiny-url:s used inside the IMG-tag?
Last edit: 17 years 1 month ago by crisscross.
- crisscross
- Junior Member
17 years 1 month ago #27692
by crisscross
Just noticed another thing that is not working. Signatures with IMG-tag that points to fbfiles/images shows the bb-code and links to the image.
Time to create page: 0.283 seconds
