Question IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
17 years 1 month ago #29552 by fortminor
crisscross wrote:
Just noticed another thing that is not working. Signatures with IMG-tag that points to fbfiles/images shows the bb-code and links to the image.
You may try to change the line 368 at kunena.parser.php
if($task->autolink_disable == 0)
with this one:
if($task->autolink_disable == 1)
Just changing 0 to 1.
This is also useful solution for those who experience problem that img's at signature automaticly link to its source.
17 years 1 month ago #29603 by NinjaSMS
Yes thank you all for your help! I downloaded the attached file by xillibit and all is working!
17 years 1 month ago #29703 by zombiebob
woot woot
replacing kunena.parser.php with the one in the zip file on this thread fixed the image display problem!!
whoop whoop! :laugh:
17 years 1 month ago #29922 by sarkit
jerry wrote:
Just back from my holiday. I am seeing inproper fix for this issue. Actually in Kunena 1.5.5 devs tried to check file extension. Both modifications from users are wrong as they disable this check.
Proper solution is:
/components/com_kunena/lib/kunena.parser.php lines: 345-348
before:
$file_ext = explode(',', $params->get('upload_extensions')); preg_match('/\.([\w\d]+)$/', $between, $matches); } if (!in_array(strtolower($matches[1]), $file_ext)) break;
after:
$file_ext = explode(',', $params->get('upload_extensions')); } preg_match('/\.([\w\d]+)$/', $between, $matches); if (!in_array(strtolower($matches[1]), $file_ext)) break;
HaND, Jerry
hv a lil problem..i m using cuteftp to chnge php..but i cant see these codes in 345-348.using kunena 1.5.5..missing something..but wht is tht..?
17 years 4 weeks ago #30152 by halo3montage
Problem fixed in 1.5.6!
Thanks Kunena Team :woohoo:
17 years 3 weeks ago #30455 by RonnyStraetling
Hi all,
don't know whats wrong with my side - there it is still the same issue with 1.5.6. I compared the coding above and it's identical. :S
Any idea?
